Zorg Posted May 27, 2009 Share Posted May 27, 2009 Is there an aliasedit in CADDuct where i can change command values? If not, is there a file within AutoCAD/CADDuct that i can modify to suit my needs? All help welcomed and appreciated. Quote Link to comment Share on other sites More sharing options...
Dave^ Posted May 27, 2009 Share Posted May 27, 2009 what do you mean exactly by 'command values'? cadduct commands can be added to the acad.pgp, but i'm guessing you already know this? Quote Link to comment Share on other sites More sharing options...
Zorg Posted May 27, 2009 Author Share Posted May 27, 2009 what do you mean exactly by 'command values'? cadduct commands can be added to the acad.pgp, but i'm guessing you already know this? err, for example SECTIONAL will cut a section when i just want it to be SEC or something. Same for ATTATCHER, I'd like it to be ATT. These can be changed in the acad.pgp file then? Z Quote Link to comment Share on other sites More sharing options...
Dave^ Posted May 27, 2009 Share Posted May 27, 2009 yep they can! simples! just type aliasedit in the command line, and add them in! use whatever shortcut you want, and use the commands in the list you posted a few weeks back..... Quote Link to comment Share on other sites More sharing options...
Dave^ Posted May 27, 2009 Share Posted May 27, 2009 here's what's in my acad.pgp AT, *ATTACHER AO, *ATTACHOFF AL, *ALIAS F2E, *FILL2ENDS FF, *FLEXFILL MT, *MOVETEXT RN, *RENUMBER SI, *SIZE RT, *ROTTEXT VPO, *VPORTS QS, *QSAVE P, *PLANVIEW 3, *3DINSPECT RD, *REDRAW R, *ROTATE S, *SECTIONAL AE, *ALIASEDIT C, *COPY CI, *CIRCLE TA, *TAKEOFF CH, *CHECK D, *DIST CL, *REVCLOUD DL, *DIMLINEAR DA, *DIMALIGNED RB, *REBUILDALL E, *ELEVS DB, *EDITDBASE DE, *DETECT SA, *SHOWALL HT, *VPTEXTS HV, *HIDESELECTEDINVP SV, *SHOWALLINVP AD, *ADDREPORT DT, *removetext Quote Link to comment Share on other sites More sharing options...
Zorg Posted May 28, 2009 Author Share Posted May 28, 2009 nice one dave!! Quote Link to comment Share on other sites More sharing options...
Dave^ Posted May 28, 2009 Share Posted May 28, 2009 no probs Quote Link to comment Share on other sites More sharing options...
