decipherd Posted June 18, 2009 Posted June 18, 2009 I have had a search for this, sorry if it has already been covered - please point me in the right direction! We are using vanilla autocad in our office, and one issue that comes up several times a week is the need to print many drawings at once - perhaps between 10-100, sometimes more on larger jobs. At the moment someone has to sit there are manually load and print every. single. file. Sure you can use 'Previous Plot' to speed the process up, but is there a better way. Has anyone developed a batch print LISP or routine? Cheers! Quote
chelsea1307 Posted June 18, 2009 Posted June 18, 2009 is there a reason you dont use publish? All you need is to have a pagesetup setup and then you plot/print multiple dwgs at once Quote
decipherd Posted June 21, 2009 Author Posted June 21, 2009 We don't use publish... but i'm not sure why - there must be a good reason, i will check this when i get in on Monday! Quote
