Single Click Pick Fence gone in 2010
I have moved to 2010 from 2008 and all is fine, however, in 2008 when I used my pick fence selection from left to right all I needed to do to complete my selections was to release the mouse.
In 2010 when I use the same selection procedure I have to left click the mouse a second time to complete the command.
I have looked everywhere to change this option...
Thanks in advance.
KC
Solved the above issue.
The option was under "selection mode" "Press and Drag"
all is good...
KC
Also known as the PICKDRAG system variable.
