KnoJa31 Posted July 28, 2009 Posted July 28, 2009 So i did a search for converting from text to mtext and i found a thread saying to use txt2mtxt. When i type that command in it says unknown command. Is there something that im missing? Quote
KnoJa31 Posted July 28, 2009 Author Posted July 28, 2009 I dont. We are currently working with a funky deployment on our servers. Initially started out with Electrical 2008 and now were going with the basic platform. Do you know of a way to add the express tools? Quote
mdbdesign Posted July 28, 2009 Posted July 28, 2009 What is version of Autocad you working currently? It is full version or LT? Quote
Ryder76 Posted July 28, 2009 Posted July 28, 2009 If you are running LT you won't be able to run LISP or use Express Tools. If not you will need the ACAD disks and install Express Tools. If you can't get the disk or have the IT people reinstall doing a Full installation and you are running Full ACAD then I can send you the txt2mtxt lisp routine and you can load it to your computer. Quote
KnoJa31 Posted July 28, 2009 Author Posted July 28, 2009 Thanks for all of help!! I had our IS department come by and reinstall. It is working now. Thank You again!! Quote
Ryder76 Posted July 28, 2009 Posted July 28, 2009 You're welcome glad you got it fixed. I would be lost without Express Tools. Autodesk should incorporate all of them. Quote
mdbdesign Posted July 28, 2009 Posted July 28, 2009 Just curiosity: why it( ET) is not incorporated? Quote
ReMark Posted July 28, 2009 Posted July 28, 2009 Express Tools Volumes 1-9 were productivity tools intended to enhance the power of AutoCAD. At one time they were included as a part of the typical installation of AutoCAD although the user could opt not to load them. They were written in English only and they were not supported much like Regclean (Registry cleaner) written by MS programmers but not supported by MicroSoft. Quote
