feargt Posted September 16, 2009 Posted September 16, 2009 Hi, I recently posted a thread about using the Filter command. I wanted to filter all polylines with heights of 50m intervals. I got that done. I was also able to save the Filter that I had created with a name. How can I share a filter that I have saved with other users? or is it even possible? Quote
rkmcswain Posted September 16, 2009 Posted September 16, 2009 When you SAVE in the Filter dialog box, a filter.nfl file is created. Copy this file to the other users machine and it will be read it when the FILTER command is started. The default path is %appdata%\Autodesk\product\version\language\Support Where the items in blue vary. This should also be equal to the value of ROAMABLEROOTPREFIX + "\Support". Quote
GAPCAD Posted August 21, 2013 Posted August 21, 2013 Thanks a lot for your postes it help me a lot. Quote
