AQucsaiJr Posted October 15, 2009 Posted October 15, 2009 Is there a command I can use to load template.dwt files so te user has access to them on start up? Or maybe a command in the ACAD.lsp file? Quote
alanjt Posted October 15, 2009 Posted October 15, 2009 Is there a command I can use to load template.dwt files so te user has access to them on start up? Or maybe a command in the ACAD.lsp file? You can set the Template and QNew template in Options. Quote
AQucsaiJr Posted October 15, 2009 Author Posted October 15, 2009 I want this to apply to every computer in my network that share the ACADDOC.lsp file so that I can stay away from going to each one and setting this up. Quote
tzframpton Posted October 15, 2009 Posted October 15, 2009 I want this to apply to every computer in my network that share the ACADDOC.lsp file so that I can stay away from going to each one and setting this up. Just set the Path in the Options > Files template directory. Just make sure it's networked, obviously. Quote
AQucsaiJr Posted October 15, 2009 Author Posted October 15, 2009 can I do that with a line in the ACADDOC.lsp file? Quote
alanjt Posted October 15, 2009 Posted October 15, 2009 can I do that with a line in the ACADDOC.lsp file? Yes, but you only need to do it once and it's set forever. This is a setup routine I wrote to set everything properly. You are more than welcome to modify and use. It has what you need to setup template paths. (defun c:CES-Setup (/ #Files #Layout #Flag) (vl-load-com) (and (not (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (setq #Files (vla-get-files (vla-get-preferences (vlax-get-acad-object)) ) ;_ vla-get-files #Layout (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)) ) ;_ vla-get-activelayout ) ;_ setq ;; ********************* ;; ** AutoSave Path ** ;; ********************* (mapcar 'vl-mkdir (list "c:\\TEMP" "c:\\TEMP\\ACAD")) (vla-put-autosavepath #Files "c:\\TEMP\\ACAD") ;; *************************** ;; ** Printer Config Path ** ;; *************************** (vla-put-PrinterConfigPath #Files "s:\\cadd standards\\Plotters" ) ;_ vla-put-PrinterConfigPath (vla-refreshplotdeviceinfo #Layout) ;; *********************** ;; ** Plotstyles Path ** ;; *********************** (vla-put-printerstylesheetpath #Files "s:\\cadd standards\\Plotstyles" ) ;_ vla-put-printerstylesheetpath (vla-refreshplotdeviceinfo #Layout) ;; ********************* ;; ** Template Path ** ;; ********************* (vla-put-TemplateDwgPath #Files "s:\\cadd standards\\Template" ) ;_ vla-put-TemplateDwgPath ;; ********************* ;; ** QNew Template ** ;; ********************* (vla-put-QNewTemplateFile #Files "s:\\cadd standards\\Template\\CES_Template.dwt" ) ;_ vla-put-QNewTemplateFile ;; ********************* ;; ** Support Paths ** ;; ********************* (vla-put-supportpath #Files (strcat ";s:\\cadd standards\\startup" ";s:\\cadd standards\\lisp" ";s:\\cadd standards\\linetypes" ";s:\\cadd standards\\fonts" ";s:\\cadd standards\\ces layers" ";" (vla-get-supportpath #Files) ) ;_ strcat ) ;_ vla-put-supportpath ;; *************************** ;; ** Tool Palettes Paths ** ;; *************************** (vla-put-ToolPalettePath #Files (strcat "S:\\CADD Standards\\Toolpalette\\Palettes;" (vla-get-ToolPalettePath #Files) ) ;_ strcat ) ;_ vla-put-ToolPalettePath ) ;_ lambda ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not (alert (strcat "AutoCAD has been setup for Capital Engineering & Surveying, Inc. Standards.\n\n" " Please restart AutoCAD." ) ;_ strcat ) ;_ alert ) ;_ and (princ) ) ;_ defun (alert "Type: \"CES-SETUP\" to run setup.") (princ) Quote
AQucsaiJr Posted October 15, 2009 Author Posted October 15, 2009 Wow... Nice... I will see what I can do with this... Thanks! Quote
alanjt Posted October 15, 2009 Posted October 15, 2009 Wow... Nice... I will see what I can do with this... Thanks! No problem, I got a nice little bonus for it when I introduced it for our 06 to 08 switch. Quote
