svorgodne Posted July 31, 2008 Posted July 31, 2008 I have the next problem: I have several projects drawn in AutoCAD 2006 and I have structured them with xrefs, sometimes I need to make changes to a specific nested xref, then I double click on it and I edit it, changing, moving, deleting, trimming, whatever, and then I cannot close the session with refclose because apparently some entities were connected somehow with some others deleted, so get a message like this: ** Application reference missing: ACAD, to AcDbMaterial. ** Object reference missing: AcDbXrecord, to AcDbDictionary. ** Application reference missing: AcDbAttr, to AcDbMaterial. It's not happening when I use AutoCad 2007 but I need to fix the problem within AutoCAD 2006 Any clue? Quote
asos2000 Posted September 11, 2008 Posted September 11, 2008 try that http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2877812&linkID=9240617 Quote
feargt Posted April 27, 2009 Posted April 27, 2009 Hi, Was wondering if the link in this thread helped you? Quote
svorgodne Posted April 27, 2009 Author Posted April 27, 2009 I had already installed that patch before, but I keep changing computers from time to time and I forgot to install it this time... it worked... thank you very much Quote
Mimi Posted June 26, 2009 Posted June 26, 2009 I had visited the link: http://usa.autodesk.com/adsk/servlet...linkID=9240617 and followed the directions on it but when I tried to run the script a small window opens up with the following message ").scr Can't find File I'm not familiar with scripts at all and do I need to put this file in my AutoCAD support folder? Please help because I'm going crazy with this "Application reference missing" message!!!!!!! Thank you. Quote
