spittle Posted November 18, 2009 Posted November 18, 2009 everytime, via button of file menu. AutoCAD just freezes. However when starting up AutoCAD, it starts like normal in a new drawing. Quote
spittle Posted November 18, 2009 Author Posted November 18, 2009 From the new installation of 2010 Quote
ReMark Posted November 18, 2009 Posted November 18, 2009 Does the computer meet the system requirements as recommended by AutoCAD? Did you experience any problems during the installation of 2010? Did you download and install Update 1 for 2010? Quote
spittle Posted November 20, 2009 Author Posted November 20, 2009 I don't think it's hardware related. I#m using 2 x Quad Core 2.66GHz Xeons, 8GB RAM Quadro FX3700, 64 bit OS. It is the 64bit version of C3D that has apparently been installed on this computer, with SP1 & 2. Quote
spittle Posted November 20, 2009 Author Posted November 20, 2009 I will try that when IT guy is back in. Also SCALELIST edit doesn't work, via command line of viewport scale dropdown. the command simply doesn't do anything - it just freezes AutoCAD until I hit escape. I recently discovered that the File\New issue freezes CAD only until I hit escape - but again the command doesn't do anything. Quote
spittle Posted November 24, 2009 Author Posted November 24, 2009 The solution: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13288548&linkID=9240697 Quote
