Please help solve VBA problem
i am having a code but there is error coming in its compliation
Can anybody solve my problem!!
ActiveDocument.ModelSpace.AddHatch
Sub Test()
   Dim pnt As IntelliCAD.Point
   Dim pnts As IntelliCAD.points
   Dim hatch As IntelliCAD.hatch
   Dim pline As IntelliCAD.LWPolyline
   Dim oLoop(0 To 0) As IntelliCAD.Entity
   ' --- Create a closed LWPolyLine
   Set pnts = Library.CreatePoints()
   Set pnt = ActiveDocument.Utility.GetPoint(, "p1:"): pnts.Add pnt.x, pnt.Y, pnt.z
   Set pnt = ActiveDocument.Utility.GetPoint(pnt, "p2:"): pnts.Add pnt.x, pnt.Y, pnt.z
   Set pnt = ActiveDocument.Utility.GetPoint(pnt, "p3:"): pnts.Add pnt.x, pnt.Y, pnt.z
   Set pnt = ActiveDocument.Utility.GetPoint(pnt, "p4:"): pnts.Add pnt.x, pnt.Y, pnt.z
   Set pline = ActiveDocument.ModelSpace.AddLightWeightPolyline(pnts)
   pline.Closed = True
   pline.Update
   ' --- Set LWPolyLine to outer loop of hatch
   Set oLoop(0) = pline
   ' --- Create a Hatch
   Set hatch = ActiveDocument.ModelSpace.AddHatch(vicHatchPatternTypePreDefined, "ANSI37")
   hatch.AppendOuterLoop oLoop
   hatch.PatternAngle = 30# ' <---------------- Hatch Angle
   hatch.PatternScale = 3# ' <--------------- Hatch Scale
   hatch.Update
   hatch.Visible = True
   ActiveDocument.Regen vicActiveViewport
End Sub
The problem seems to be that you are trying to use Intellicad Reference, but with AppendOutherLoop method, wich is part of AutoCad Reference.
Remove that line and use Object.ApplyHatch (SelectionSet)
Where selectionset is the selectionset containing the object to be hatched (sorry),
If you use IntelliCAD I would recommend switching to Bricscad. There you have the same object model as in AutoCAD, both in VBA, VLisp and C++.
