Inventor 2010 Tutorial: Create and pattern a hole
In the Inventor 2010 Tutorial Create and pattern a hole in step 10. it says:
Set the count to two and then highlight the text in dimension spacing field. With the text highlighted, select the horizontal sketch dimension to use the dimension value for the spacing.
The problem is that once the hole is created the dimensions disappear...
Anyone know how to solve this?
Ps. does anyone know if there is anywhere on the web someone might have uploaded these tutorials solved in video? (That way I can see if there is something I am doing wrong)
Right click on the sketch and make it Visible.
