"0" Z level
After a complex solid exploded. What is the simple way to bring all the lines together with curves and arc etc. on one flat level please? So a 2D plan can be produced.
Thanks.
Link to post
If you dont have the Express Tools FLATTEN command put the following string onto a button, it does roughly the same thing -
^C^C_select;all;;_move;p;;0,0,0;0,0,1e99;_move;_p; ;0,0,0;0,0,-1e99;^M;
Alternatively select everything in the drawing and use the properties box to set the Z-coordinates to zero.
Link to post
I used this method but didn't and still doesn't work. The lines end at different levels. :huh:
Link to post
Did you try moving objects to "0,0,1e99" then "0,0,-1e99"?
It should work via properties box also, but you may need to filter out other than lines, and then set start end end z values to 0.
Link to post
