dreamer Posted December 13, 2009 Share Posted December 13, 2009 After a complex solid exploded. What is the simple way to bring all the lines together with curves and arc etc. on one flat level please? So a 2D plan can be produced. Thanks. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 13, 2009 Share Posted December 13, 2009 I would not have exploded anything, but you might try flatten command. Quote Link to comment Share on other sites More sharing options...
nukecad Posted December 13, 2009 Share Posted December 13, 2009 If you dont have the Express Tools FLATTEN command put the following string onto a button, it does roughly the same thing - ^C^C_select;all;;_move;p;;0,0,0;0,0,1e99;_move;_p; ;0,0,0;0,0,-1e99;^M; Alternatively select everything in the drawing and use the properties box to set the Z-coordinates to zero. Quote Link to comment Share on other sites More sharing options...
dreamer Posted December 13, 2009 Author Share Posted December 13, 2009 If you dont have the Express Tools FLATTEN command put the following string onto a button, it does roughly the same thing - Alternatively select everything in the drawing and use the properties box to set the Z-coordinates to zero. I used this method but didn't and still doesn't work. The lines end at different levels. Quote Link to comment Share on other sites More sharing options...
CarlB Posted December 14, 2009 Share Posted December 14, 2009 Did you try moving objects to "0,0,1e99" then "0,0,-1e99"? It should work via properties box also, but you may need to filter out other than lines, and then set start end end z values to 0. Quote Link to comment Share on other sites More sharing options...
