Hello everybody, I am new to forum and I'm trying to figure out the easiest way to transform this drawing into a 3d solid model. Any help will be greatly appreciated. Thanks!
Drawing1.dwg
Extrude the base plate with the required thickness.
Draw the centre line of the other object.
Extrude the circle using this centre line as the path of extrusion
Hope that clears your doubts.
Although you cant do it in lt, but this is the way.
Regards
Vivian
3d model.dwg
