Description Key Symbols Scaling
Hello,
I am trying to scale the point symbols brought in by the description key manager in LDD 2008. Currently I am going into the description key manger,into the table,picking on the particular description key,going to the scale/rotate tab....then changing the scale by mathematical proportion....with many symbols this is very laborious....is there a way to change all the symbols in the description key file all at once?
Thanks for your continued help, rlshound
I don't really understand what you're trying to do... What is "scale by mathematical proportion"?
Are you saying that you want the symbols to be a different size, depending on the scale of your final printed drawing? To do that, setup your description keys so they use the "Current Dwg Scale" option. Then set your Drawing Scale appropriately before you bring the points into your drawing.
