Hi Lee, (and everyone else)
hopefully i can explain enough of what i am after.
what i need is a .lsp routine that when i select a polyline in Cad it will place the points in a table with the point number and Easting and Northing, i do not need the Radius, just the 3 colums Point, Easting and Northing, i would love it if it could also number the points on the polyline to the points in the table.
what i am also after is for the table to have fields so that when i move the point the Easting and Northing updates Automatically.
hoping i have made sense, and sorry for the huge request
any help would be greatly appreciated
Emily
Hi Emily,
I'm not sure this is possible using Fields with the Polyline object - as fields do not account for this property.
It does have workarounds however - for example, you could have a point at every polyline vertex and use the point position in the field - but this is less than desirable.
Alternatively this could be done through the use of reactors - but it would be a complex program indeed to couple that many items effectively.
Lee
Ohh boo, thought i was pushing my luck....hahaha :-)
thankyou very mcuh for the info Lee,
for the workaround that would be very useful to me as i am working with points and my Colleague is working with the Polyline, so i was trying to get him a routine for the PLine.
is there a lsp routine available for the points one??
thanks for the links PS_Port,
i will go take a look now
Hows this?
(defun c:pt2fld (/ *error* COL ENT I LST OBJLST PT ROW SPC SS STR TSS UFLAG)
 (vl-load-com)
 ;; Lee Mac  ~  09.02.10
 (defun *error* (msg)
   (and uFlag (vla-EndUndoMark *doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (setq *doc (cond (*doc) ((vla-get-ActiveDocument
                            (vlax-get-acad-object)))))
 (setq spc  (if (zerop (vla-get-ActiveSpace *doc))
              (vla-get-PaperSpace *doc)
              (vla-get-ModelSpace *doc)))
 (if (setq i -1 tss (ssget "_X" '((0 . "ACAD_TABLE"))))
   (while (setq ent (ssname tss (setq i (1+ i))))
     (setq ObjLst
       (cons
         (vlax-ename->vla-object ent) ObjLst))))
 (if (setq i -1 ss (ssget '((0 . "POINT"))))
   (while (and (setq ent (ssname ss (setq i (1+ i))))
               (setq pt  (getpoint "\nSelect Point for Field: ")))
     (setq uFlag (not (vla-StartUndoMark *doc)))
     (setq Str (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                       (itoa (vla-get-ObjectId
                               (vlax-ename->vla-object ent)))
                       ">%).Coordinates \\f \"%lu2%pr2\">%"))
     (cond (  (setq lst
                (car
                  (vl-remove-if (function null)
                    (mapcar
                      (function
                        (lambda (table)
                          (if (eq :vlax-true
                                (vla-HitTest table
                                  (vlax-3D-point (trans pt 1 0))
                                    (vlax-3D-point
                                      (trans (getvar 'VIEWDIR) 1 0)) 'row 'col))
                            (list table row col)))) ObjLst))))
                (apply (function vla-SetText)
                       (append lst (list Str))))
           (t  (vla-AddMText spc
                 (vlax-3D-point pt) 0. str)))
     (setq uFlag (vla-EndUndoMark *doc))))
 (vla-regen *doc acActiveViewport)
 (princ))
Lee that is brilliant, :-)
a few requests if possible though,
the routine says select objects which i do, but does not automatically place the text next to points, i have to remember in which order i selected the text.
is it possible to modify the text to make this happen??
also now once i have that done, is there a way to quickly get those Co-ords into a table(besides EATTEXT command),
thankyou so much for your time and help,
Yeah, currently the user can click in a table cell to put it there - but I wasn't sure about what the table format should be? Just one column of points?
if possible
i am after 3 Columns.
POINT, EASTING and NORTHING
:geek::D
Hi Emily,
Try this:
(defun c:pt2fld (/ *error* ENT I J LLST OBJ PT SPC SS STRLST TBLOBJ UFLAG)
 (vl-load-com)
   (princ))
 (if (and (setq i -1 ss (ssget '((0 . "POINT"))))
          (setq pt (getpoint "\nPoint for Table: ")))
     (while (setq ent (ssname ss (setq i (1+ i))))
       (setq StrLst (cons
                      (list (itoa (1+ i))
                                            (setq obj (vlax-ename->vla-object ent))))
                                    ">%).Coordinates \\f \"%lu2%pt1%pr2\">%")
                                    (itoa (vla-get-ObjectId obj))
                                    ">%).Coordinates \\f \"%lu2%pt2%pr2\">%")) StrLst))
       (setq lLst (append (mapcar
                            (function
                              (lambda (x) (strlen (rtos x 2 2))))
                            (cdr (assoc 10 (entget ent)))) lLst))
       (vla-put-Alignment
         (setq tObj
           (vla-AddText spc (itoa (1+ i))
             (vla-get-Coordinates obj) (getvar 'TEXTSIZE))) acAlignmentMiddleCenter)
       (vla-put-TextAlignmentPoint tObj (vla-get-Coordinates obj)))
     (setq tblObj
       (vla-AddTable spc (vlax-3D-point pt)
         (+ 2 (length StrLst)) 3
           (* 1.2 (getvar 'TEXTSIZE))
           (* (apply (function max) (append '( lLst)) 1.5 (getvar 'TEXTSIZE))))
     (vla-SetText tblObj 0 0 "Emily's Points :-)")
     (setq i 1 j -1)
     (mapcar
       (function
         (lambda (x)
           (vla-SetText tblObj i (setq j (1+ j)) x)))
       '("POINT" "EASTING" "NORTHING"))
     (setq j 0)
     (mapcar
       (function
         (lambda (x)
           (setq i (1+ i) j -1)
           (mapcar
             (function
               (lambda (y)
                 (vla-SetText tblObj i (setq j (1+ j)) y))) x)))
       (reverse StrLst))
 (princ))
Lee, What can i say,
Absolutely spot on, i can't wait to get the hang of Lisp.
Many Many thanks
EMily
You're welcome Emily :)
Just found I left an unnecessary remnant from the other version in it - code updated. :)
  • 2 months later...
Lee, can I maybe ask if you could make the number that the lisp creates for each point to be added into the table as a field as well. (same as coordinates)
I have tried to change code to do this but have not been able to be successful.
i.e. The code will make a table with the Number inserted as before but also linked as a field.
Don't know if this make sense to you.
PS: thanks a lot for all the great help so far.
