Can any one help me please. I still can not solve the some-what see-through problem with 3D Hidden, Conceptual & Realistic Visual Styles. I checked and certain that no items overlapping.
Thanks in advance.
try setting DISPSILH=0
ISOLINES=0
VSEDGES=0
VSOBSCUREDEDGES=0
or better yet try tweaking on the VISUALSTYLES settings
Thank you iskalipsi.
Tried all the four settings and tweaked those at the VISUALSTYLES Manager. The same setting fixed the problem on one drawing while the other made worst.
Are these settings once set remain the same to all drawings?
From AutoCAD Help: "In a script, the VISUALSTYLES command does not automatically suppress the Visual Styles Manager. You must use -visualstyles to display command prompts." - Although it's in simple English but I do not quite understand what it means. Can you help please?
Thanks.
If you're not using a script file of some sort to batch process a group of drawings then there should be nothing to worry about.
