Perseus Posted October 14, 2005 Share Posted October 14, 2005 I am very new to 3d drawing in autocad. I am constructing the plans for a bed and could use some help on an issue. Where I am joining 2 solids (like plywood sitting in a dado joint), how can I have one solid be carved out where the 2nd solid overlaps it, without deleting the 2nd solid. Pretty much what SUBTRACT does but without the deleting. Thanks. Scott Quote Link to comment Share on other sites More sharing options...
CarlB Posted October 14, 2005 Share Posted October 14, 2005 Just a thought; Copy parts A & B on top of itself so you have duplicates. First subtract A from B, then subtract B from A. Each operation will remove the "overlap", leaving the remainder of the original. Quote Link to comment Share on other sites More sharing options...
hendie Posted October 14, 2005 Share Posted October 14, 2005 have a look at the DELOBJ system variable Quote Link to comment Share on other sites More sharing options...
Perseus Posted October 14, 2005 Author Share Posted October 14, 2005 Thanks for the quick replies I tried the DELOBJ. And it seems to just leave behind the 2D drawing after I extrude to 3D. But the 2nd part of SUBTRACT still gets deleted, leaving the 2D part behind. The COPY method works good. Maybe a little extra effort, but functional. I would of thought there would be an option to NOT delete the object. Again thanks Scott Quote Link to comment Share on other sites More sharing options...
hendie Posted October 14, 2005 Share Posted October 14, 2005 you could use the INTERFERENCE command, create the interference then subtract that from your solid Quote Link to comment Share on other sites More sharing options...
Perseus Posted October 15, 2005 Author Share Posted October 15, 2005 Hey that works pretty well too. Thanks very much for the extra info. Scott Quote Link to comment Share on other sites More sharing options...
ixyak Posted July 9, 2011 Share Posted July 9, 2011 you could use the INTERFERENCE command did u mean typing INTERFERENCE on a command prompt? cos the command doesn't exist, please help i'm using Autocad 2011 Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 9, 2011 Share Posted July 9, 2011 did u mean typing INTERFERENCE on a command prompt? cos the command doesn't exist That's because the command is INTERFERE, not Interference. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted July 9, 2011 Share Posted July 9, 2011 Copy the solid you want to remove with a 0,0,0 base point. Use SUBTRACT to remove the solid you just copied from the solid that you want the body removed from. Paste the copied solid back to the 0,0,0 base point. Quote Link to comment Share on other sites More sharing options...
lamensterms Posted September 7, 2011 Share Posted September 7, 2011 I was pretty sure autocad used to prompt you and ask if you would like to delete the subracted solid. but apparently this isnt the case. after testing this i have found that it is a lisp routine i am running which will ask you if you wish to keep the original subtracted solid (similar to how the mirror command asks you if you want to keep or delete the original element). (Defun c:sub (/ SS1 SS2 YNTST1 OS) (setvar "cmdecho" 0) (command "undo" "be") (prompt "\nSUBTRACT Select objects and regions to subtract from ..") (setq SS1 (ssget)) (prompt "\nSelect solids and regions to subtract ..") (setq SS2 (ssget)) (if (= YNTST nil)(setq YNTST "No")) (initget "No Yes") (setq YNTST1 (getkword (strcat "\nDelete the objects selected to subtract ? \(Y/N\) <" YNTST "> : "))) (if (= YNTST1 nil)(setq YNTST1 YNTST)(setq YNTST YNTST1)) (if (= YNTST1 "No") (progn (setq OS (getvar "osmode")) (setvar "osmode" 0) (command "copy" SS2 "" "0,0,0" "0,0,0") (setvar "osmode" OS) ) ) (command "subtract" SS1 "" SS2 "") (command "undo" "e") (setvar "cmdecho" 1) (princ) ) is the routine. good luck mate. Quote Link to comment Share on other sites More sharing options...
lamensterms Posted September 7, 2011 Share Posted September 7, 2011 also note that this routine will do exactly as SuperCAD described. cheers. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 8, 2011 Share Posted September 8, 2011 I am very new to 3d drawing in autocad. If you are a student you might download a next generation 3D CAD program like Autodesk Inventor and avoid these limitations. Students can get Inventor for free from http://www.autodesk.com/edcommunity Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 8, 2011 Share Posted September 8, 2011 If you are a student you might download a next generation 3D CAD program like Autodesk Inventor and avoid these limitations.Students can get Inventor for free from http://www.autodesk.com/edcommunity Gotcha again JD. Perseus started this thread 6 years ago. Quote Link to comment Share on other sites More sharing options...
ShawnTTCoop Posted September 8, 2011 Share Posted September 8, 2011 I think Inventor asks if you want to delete the subtracted solid. I am not sure though, as it has been months since I have used Inventor to create anything Quote Link to comment Share on other sites More sharing options...
ShawnTTCoop Posted September 8, 2011 Share Posted September 8, 2011 Gotcha again JD. Perseus started this thread 6 years ago. I really have to start reading these threads all the way before I reply Quote Link to comment Share on other sites More sharing options...
pizarro Posted November 3, 2019 Share Posted November 3, 2019 Please, you can modify the routine to subtract several solids from another group of solids, without eliminating the first and without joining the seconds. Thank you very much for the reply. Quote Link to comment Share on other sites More sharing options...
