Im new to AutoCAD 2010 but have used 2008 for quite a while. This is quite a hard problem to explain but i'll give it a go....
When orbiting around a 3D model in 2010 i have had problems. Using 2008 i could zoom in and orbit/pan around using shift+middle mouse wheel and generally speaking you would orbit around the crosshairs. When modeling in 2010 unless i select the object im working on to orbit around, the pivot point for the orbit is off. How do you set your pivot point for orbit to be your crosshairs/your current view????
