rob150588 Posted February 23, 2010 Posted February 23, 2010 Morning/Evening all, I'm having a rather frustrating problem that I'm hoping someone may be able to shed some light on. For information, I'm using AC2010 64bit (evil program ). When I save certain drawings, regardless of what visual styles are applied to a viewport at the time, the visual style changes to 3D wireframe. The view changes to perspective projection and the sunlight is turned on. This change happens everytime I press save. This is odd as I never use the 3D wireframe style. There are no named views in the drawing aside the AutoCAD default ones either. A recent development to the problem is that it is caused after producing a rendered image, so I can now reproduce the problem like clockwork...but cannot stop it happening. Help ? Anyone ? Rob. Quote
tutt Posted September 2, 2010 Posted September 2, 2010 I´ve got the exact same problem! And I´ve had it since i first installed autocad. It seems to be bound to the drawing at some point during a render process, then the problem is stuck to the drawing until i kill the dwg file. I use Autocad Architecture 2011 but I had the same problem with 2010. Did you solve this? Anyone who know why this happens or can figure it out? Thank you! Quote
rob150588 Posted September 2, 2010 Author Posted September 2, 2010 Nope, never found a solution to it. The only workaround was to save the drawing as a new drawing e.g. "blahblah_render.dwg" and render it there. Not ideal, but it works. Quote
threeoclock Posted October 27, 2010 Posted October 27, 2010 Hello. I had the same problem, rendered an image and every subsequent save changed the visual style to 3D wireframe. The way I have found to do it is to "save as," and save it with the same name, it will keep the visual style you have been using. Not a fix, but perhaps an easier workaround. Quote
