Saving .idw to Autocad .dwg problem?
I have saved a plan view of my .idw to an autocad .dwg drawing, the drawing opens fine in Autocad but for some reason it will not explode. Is there any way around this?
I think you need to post this question in the Inventor forum.
Here is some information from an Autodesk employee
read-16x16.gif DWG TrueConnect tips
Posted: Feb 24, 2010 2:01 PM reply-16x16.gif Reply
I wanted to make people aware of some information regarding DWG TrueConnect
drawings, aka Inventor DWG files.
1. DWG TrueConnect drawings are a collaboration tool intended to be used
like a DWF outside of Inventor. The following operations are supported:
- View/Plot
- Precise & correct scale measurements of view geometry using DIST or by
temporarily creating AutoCAD dimensions.
- Turning layers on/off
- Copy/Reuse of view geometry by inserting view blocks into another DWG
using Design Center
- Xref-ing of a single view into another DWG by inserting it into
modelspace then Xref-ing the Inventor DWG. (plant layout?)
2. Inventor DWG files are not intended to support general editing within
AutoCAD. Save Copy As AutoCAD .dwg should still be used when you want to
"publish" a DWG to be used by an AutoCAD user with no restrictions.
3. You can also convert an Inventor DWG to a fully editable modelspace DWG
using AutoCAD's "EXPORTLAYOUT" command. (Make sure you have the latest
service packs installed though, some fixes were made to support Inventor
DWG.) This will produce a 100% visual fidelity, 100% editable modelspace
DWG. The downside though is that annotations and dimensions are simply
blocks. To preserve the intelligence, use Save Copy As AutoCAD .dwg from
Inventor.
4. There is a "backdoor" way to change the Inventor view geometry in-place,
you can insert the view block, REFEDIT it, then the changes will show up in
the viewport. However, these changes will be reverted if you open the
Inventor DWG in Inventor. As long as the DWG is attached to the Inventor
model, we need to preserve the associativity of the view geometry at all
costs. There is one other issue, if you increase the X or Y extents of the
view block, the geometry *may* get clipped when its displayed in the
viewport. Its possible but quite tricking to expand the viewport boundary
without messing up the view scale (we make the boundary invisible so you
can't grip edit), so this trick should be used as a last resort.
If anyone has questions or concerns about DWG TrueConnect, or any other
unmet needs in the area of DWG interoperability, please respond and I will
do my best to respond.
Robert McMillan
Autodesk Inventor Developer
