How to copy a list of files from one directory to another?
MarcoW
Hello,
I have a need for following lisp: when executed it should check where the current CTB files are stored (with (getenv "PrinterStyleSheetDir"))).
It should copy all the *.ctb files into another folder that allready exists: "c:\program files\MarcoW\".
This is what I have found to be working for 1 file, in this case a text file:
(vl-file-copy (findfile "atextfile.txt") "c:\\atextfile.txt")
So I figured, I should make a list out of * .ctb files in the current PrinterStyleSheetDir. That is what I do not know how to do. All I find is getfiled functions. Because that prompts to select file, I cannot use it.
The "findfile" function uses the support file search paths so that won't work either.
Do you know a solution? Thanks in advance!
My attempt so far:
(defun c:CopyCtb ( / ); localizing later
(setq
; get current directory for *.ctb files
cPrinterStyleSheetDir (getenv "PrinterStyleSheetDir")
; get current directory program files
cProgramFiles (getenv "programfiles")
; the new *.ctb files directory
nPrinterStyleSheetDir (strcat cProgramFiles "\MarcoW\Plotter\")
); end of setq
; here the part to get all CTB files in the current "env PrinterStyleSheetDir"
(princ)); end of defun
AlanJT's subroutine might be of help??... but I do not know how to use it...
;;; Copy entire contents of directory to new location (subfolders included)
;;; #Source - source folder to copy
;;; #Dest - destination directory (will be created if doesn't exist)
;;; Alan J. Thompson, 10.06.09
(defun AT:XCopyDirectory (#Source #Dest / *error* #Scr)
 (setq *error* (lambda (x) (and #Scr (vlax-release-object #Scr))))
 (cond ((findfile #Source)
        (setq #Scr (vlax-get-or-create-object "WScript.Shell"))
        (vlax-invoke-method #Scr "Run" (strcat "XCopy " #Source " /E /H /Q /Y /I " #Dest) 0)
 ) ;_ cond
 (*error* nil)
) ;_ defun
Not as fancy as Alan's use of the Windows Script Host, but this is one way to copy all files in a directory (not including subdirectories).
(defun CopyFiles (dir typ dest)
 (vl-load-com)
 (foreach file (vl-directory-files dir typ 1)
   (vl-file-copy (strcat dir file) (strcat dest file)))
 (princ))
dir : Source Directory (use double backslashes)
typ : type of files (DOS pattern, eg "*.dwg")
dest : Destination Directory (must be valid)
 ) ;_ cond
 (*error* nil)
) ;_ defun
It will copy everything within one directory (including sub-directories) to another. If the destination does not exist, it will be created. I used XCopy to easily copy all sub-directories and WScript to avoid any annoying Dos windows.
 (vl-load-com)
 (princ))
I'm pretty sure vl-file-copy will fail if it can't find the destination directory.
Exactly, which is why I said the destination directory 'must be valid.'
Oops, missed that. I think I also have one similar to the one you posted in the subroutine thread I started.
 (vl-load-com)
 (princ))
I am about to explode :x
Why is this not working?
(vl-load-com)
(setq
cProgramFiles (getenv "ProgramFiles")
nPrinterStyleSheetDir (strcat cProgramFiles "\\MarcoW\\Plotter\\")
(foreach file (vl-directory-files cPrinterStyleSheetDir "*.ctb" 1)
 (vl-file-copy
  (strcat cPrinterStyleSheetDir file) (strcat nPrinterStyleSheetDir file)))
yes it does but maybe i should make it a bit simple..?
like c:\\marcow\\
edit:
yes this works..
(vl-load-com)
(foreach file (vl-directory-files "c:\\map1\\" "*.txt" 1)
(vl-file-copy (strcat "c:\\map1\\" file) (strcat "c:\\map2\\" file)))
I must have made a mistake...
I see your problem -
Bear in mind that
Will not end with "\\", and when you are concatenating it with the file, it needs a "\\" to make it a valid filepath.
You are right :-)
This is working now:
(vl-load-com)
(setq
cPrinterStyleSheetDir [b][color=red](strcat[/color][/b] (getenv "PrinterStyleSheetDir") [b][color=red]"\\")[/color][/b]
