acad 2004 help
xolent
Hi there,
fairly new to acad and i'm using 2004
i've been using it on and off for about 3 months now...just got a quick question.
I use to be able to draw a line, right click and it will show the properties of the line or pline, now that's no more. I use to be able to go into the properties and adjust the world weight of it and so on...
This disappeared around the time when I use to could delete lines with the delete button...now i have to use the eraser...is there some sort of setting that turned on/off accidentally?
