michaeloureiro Posted August 21, 2008 Share Posted August 21, 2008 Hey everybody, Recently i tried to export a corel drawing to dwg format and found that cad slowed down considerably when i opened the drawing. Is there anything that i´m doing wrong? Is there another way to export corel drawings to dwg? Thanks Quote Link to comment Share on other sites More sharing options...
fuccaro Posted August 21, 2008 Share Posted August 21, 2008 You can export from Corel in DWG of in DXF format. After opening in AutoCAD you may try overkill/purge. Also if there are a lot of texts and all are exported as curves you can get a big file-size in AutoCAD. Quote Link to comment Share on other sites More sharing options...
michaeloureiro Posted August 22, 2008 Author Share Posted August 22, 2008 Merci fuccaro Quote Link to comment Share on other sites More sharing options...
Lazer Posted August 24, 2008 Share Posted August 24, 2008 I often delete the imported text and redo it in Autocad, this reduces the file size. Quote Link to comment Share on other sites More sharing options...
