manyee Posted August 21, 2008 Share Posted August 21, 2008 Hi, I'm trying to create some Dynamic Block in Autocad 2006. After putting some parameters and actions together in one block, the text/annotation size get very big that practically cover the block whenever I open the block in block editor. When I move the text/annotation in the block editor, they suddenly shrink to normal. But when I try to open it again later on, they come out very big again. Is there a way to keep the text/annotation of those actions & parameter to stay in one size when I open the block editor? Thanks guys Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 21, 2008 Share Posted August 21, 2008 not that I know of but you can regen or click the icon with a square and a couple of arrows to get it all small again Quote Link to comment Share on other sites More sharing options...
manyee Posted August 21, 2008 Author Share Posted August 21, 2008 Thanks for the quick reply. Yes, I can always click the Update Par & Action Text button, but it's time consuming because I have to zoom in or out several times to get the correct size. I'm wondering if I can make the text size stay the same after I close the block editor. Quote Link to comment Share on other sites More sharing options...
BenE Posted August 21, 2008 Share Posted August 21, 2008 When you're in block editor, is your annotation scale set to the same scale as your annotative text? Quote Link to comment Share on other sites More sharing options...
manyee Posted August 23, 2008 Author Share Posted August 23, 2008 Yes, they're all the same. When you're in block editor, is your annotation scale set to the same scale as your annotative text? Quote Link to comment Share on other sites More sharing options...
