I am needing to have a decent size dimension text. Is there a limit to how high the text can be? When I try to create a text height, i.e. 8.0, it doesnt change the height to that my text is staying small.
I don't know about inventor but assuming it is like AutoCAD, there is no maximum. HOWEVER if you have declared a height in the text STYLE that is what you are stuck with. Just check that all text styles have their height set to 0 before adjusting it any where else.
thanks, by the way this particular issue is in Mechanical Desktop
Thanks dbroada, that is what the problem was someone before me had set the height to a certain amount.
no problem - a common mistake.
Is your profile wrong or do you use both Inventor & Mech Desktop?
