ReMark Posted September 1, 2008 Share Posted September 1, 2008 You can also use regions. After turning each rectangle into a region subtract the inner one from the outer one. Visually, it will appear that nothing happened but looking at the command line will tell you different. Then use the extrude command. The "space" in the middle will show up just as you expected. Quote Link to comment Share on other sites More sharing options...
