e.mounir Posted August 27, 2008 Share Posted August 27, 2008 The best way to draw match line 1- make match line and brake line with over lab area in each part (note: I will repeated the information in two drawing ) 2- make match line only without brake line ( sometime the match line found in the critical area like expansion joint ) Can any one help me to chose one or tell me another way Regards, Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 27, 2008 Share Posted August 27, 2008 Please don't cross post. I have deleted your other duplicate thread. Can you provide more information about what you're trying to do? Screenshots are also helpful. Quote Link to comment Share on other sites More sharing options...
chulse Posted August 27, 2008 Share Posted August 27, 2008 I like to show matchlines as a wide pline sent to the back of the model and screened very light so it doesn't interfere with the detail of the drawing. Quote Link to comment Share on other sites More sharing options...
e.mounir Posted August 27, 2008 Author Share Posted August 27, 2008 sory this is my first post find attachd two option dwg.zip Quote Link to comment Share on other sites More sharing options...
rkent Posted August 28, 2008 Share Posted August 28, 2008 Wide pline with phantom line type, don't show the same information on both drawings, the match line should start and stop at the same place. Quote Link to comment Share on other sites More sharing options...
Igopako Posted August 28, 2008 Share Posted August 28, 2008 rkent is right....I have questions too how can i set my UCS if I want to draw in 2D and 3D in one single model space dwg??? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 28, 2008 Share Posted August 28, 2008 In Model Space, type VPORTS at the command line to open the "Viewports" dialog. You can choose the setup you want from there. Once you have viewports, you can set your UCS for each one. In the future, it would be better if you start a new thread when you have a question. This thread is about matchlines, not UCS. Quote Link to comment Share on other sites More sharing options...
Igopako Posted August 28, 2008 Share Posted August 28, 2008 cool thx, im a newbie next time....ill start a new post.... Quote Link to comment Share on other sites More sharing options...
