enemigoman Posted May 18, 2010 Share Posted May 18, 2010 Hello: I use ACAD 2010 32bit and have the following problem: Every time I open any drawing, the file acad.lsp is created/copied in the directory where the opened file is saved. This happens just by opening the file; I don't even need to save it. This started to happen when I, in my infinite wisdom, closed a warning message without reading it and, on top of it, checked the "Do not show me this message again" square. I only remember that it said "acad.lsp", but nothing else. How stupid was that, uh? Now this does not affect really the work, but since I work in a network environment, my colleagues find the emergence of this file annoying. Needless to say all of us are completely LISP-illiterate and, therefore, LISP-fobic. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
enemigoman Posted May 18, 2010 Author Share Posted May 18, 2010 Let me update you with something I just found out: The problem happens only with the first file opened by ACAD. Once ACAD is runing and I open further drawings, there is no problem. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 18, 2010 Share Posted May 18, 2010 Well, the message about "acad.lsp" that you probably got was just a fancy message about the ACADLSPASDOC system variable, which should be set to 0. But there is also a AutoCAD lisp virus out there that makes copies of this and other files. See: http://support.autodesk.com/getDoc.asp?id=TS13717811 and consult with your reseller or other help if needed. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 18, 2010 Share Posted May 18, 2010 I think if you want to see the message you missed you can do so by going to Tools > Options > System tab > and look in the upper right hand corner for a button labeled Hidden Messages Settings. Quote Link to comment Share on other sites More sharing options...
