Hi All,
how can I say this in autolisp:
(if (= a b) then do these (xxx) (xx) (xxxx)
I want to do several things after having a=b.
I wrote:
(if (= a b) ((xxx) (xx) (xxxx))
but for some reasons doesn't work!
can you please help me with this?
Cheers
Ali
got it!
(progn (xxx) (xx) (xxxx))
Progn is your new friend.
The (if (A) (B) ©) means: if A is true then do B else do C.
to do more "things" use the (progn...) command.
(if (A) (progn B1 B2 B3) (progn C1 C2...))
This structure can be translated as: If A is true then do B1, after that do B2, B3; If A is not true then do C1, c2,...
You found it out by yourself. This knowledge is more valuable.
Thanks mate,
As always explained it very nice.
Yes, I found it by searching the help. As I used to programming in Basic when I was at high-school I am familiar a little bit with programming so I was guessing something like that should be exist.
autoLISP is fantastic!!!
I am new and just started a week ago but found it incredible.
Thanks All for your support
Ali
