srikanthkamuju Posted May 19, 2010 Posted May 19, 2010 Hi All, I am working on VB as front end and back end as autocad. my requirement is if autocad is not installed in my system . when ever my application runs it will display a message autocad is not installed in your system thanks in advance Quote
ReMark Posted May 19, 2010 Posted May 19, 2010 Your request is a bit puzzling. How would you not know that AutoCAD was loaded on your system? I know exactly what is loaded on my computer and I don't even have to turn it on and run a code. Even if you were to go to a computer that isn't yours, figuring out if AutoCAD were loaded on it without running any code would seem fairly simple to determine. Maybe I'm missing something here. What exactly are you trying to accomplish? Quote
srikanthkamuju Posted May 19, 2010 Author Posted May 19, 2010 Your request is a bit puzzling. How would you not know that AutoCAD was loaded on your system? I know exactly what is loaded on my computer and I don't even have to turn it on and run a code. Even if you were to go to a computer that isn't yours, figuring out if AutoCAD were loaded on it without running any code would seem fairly simple to determine. Maybe I'm missing something here. What exactly are you trying to accomplish? for example: If i develop one project in vb. suppose if i will that project . while loading my project first it load autocad application if the autocad is not installed then it should display a message Quote
ReMark Posted May 19, 2010 Posted May 19, 2010 Ah, I see. Thank you for clearing that up. Makes more sense now. Quote
MSasu Posted May 19, 2010 Posted May 19, 2010 You may try something like this: Function IsAcadAvailable() As Boolean On Error GoTo ErrAction Set theAcadApp = CreateObject("AutoCAD.Application") 'call default version IsAcadAvailable = True Set theAcadApp = Nothing ExitAction: Exit Function ErrAction: IsAcadAvailable = False Resume ExitAction End Function Regards, Quote
MSasu Posted May 19, 2010 Posted May 19, 2010 @ReMark: It is a good programming practice to ensure that the workstation where your application will be used has the required resources; since sometime he have no information about the user some validation tests are mandatory. In this case, if I understand correctly, the OP wants to access AutoCAD from a stand-alone application written in Visual Basic. So, his application, instead of crashing each time the user try to start it, it will inform him/her that an AutoCAD installation is required to use that tool. Quote
