shellb Posted August 28, 2008 Share Posted August 28, 2008 Hi guys, Does anyone know if you can rotate of viewport? I don't remember ever learning that...and I don't see it in the viewport options. Basically I have a co-worker that wants to rotate the viewport so they don't have to rotate the drawing... Many thanks, Quote Link to comment Share on other sites More sharing options...
YZ Posted August 28, 2008 Share Posted August 28, 2008 2005 had a function called DVIEW, or Dynamic View. If you select the model, or just one or two objects you want to align with the paper space, type DVIEW and it will bring up a series of options. You want the TWist option, so type TW. You can then type of use the mouse to set the twist angle. It does not rotate the model, but effectively twists the paper space around so the model displays at a different orientation relative to the paper. (When I got LT 2008 that feature had disappeared, so I'm not sure about the full version. Someone else may be able to confirm that...) Quote Link to comment Share on other sites More sharing options...
rkent Posted August 28, 2008 Share Posted August 28, 2008 DVIEW or UCS, Z, angle. Plan, Current. To get back, UCS, World. Plan, World. Quote Link to comment Share on other sites More sharing options...
shellb Posted August 28, 2008 Author Share Posted August 28, 2008 Sorry...I should have given some more info. It's 2D and its a floor plan. Also...he only wants to rotate the "view" in paper space...not in model space Basically his drawing won't fit on one page as 1/8 so he needs to cut it (half on each page). For some reason he dosn't want to rotate it in model space only in paper space? I think he is going to make do with what he has...however, since the topic was brought up the question of locking a veiwport view and rotating that view came up. We are just wondering if that is an option or not. I hope this makes sense, because now it is sounding kinda crazy. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 28, 2008 Share Posted August 28, 2008 Sorry...I should have given some more info. It's 2D and its a floor plan. Also...he only wants to rotate the "view" in paper space...not in model space Basically his drawing won't fit on one page as 1/8 so he needs to cut it (half on each page). For some reason he dosn't want to rotate it in model space only in paper space? I think he is going to make do with what he has...however, since the topic was brought up the question of locking a veiwport view and rotating that view came up. We are just wondering if that is an option or not. I hope this makes sense, because now it is sounding kinda crazy. The answers given will do exactly what you are after. While in PS make a viewport current and use Dview or the UCS and Plan commands as described. 2009 has an add on that makes rotating the viewport easier. Quote Link to comment Share on other sites More sharing options...
shellb Posted August 28, 2008 Author Share Posted August 28, 2008 Cool, thanks. I achieved the desired effect and showed him how. Many thanks, a cool tool for future use. Quote Link to comment Share on other sites More sharing options...
khama Posted September 1, 2008 Share Posted September 1, 2008 Cool, thanks. I achieved the desired effect and showed him how. Many thanks, a cool tool for future use. try the UCSFOLLOW command type in ucsfollow and set it to 1 go to your viewport and spin your z axis to the required angle your viewport will change but modelspace will be in the same position type in ucsfollow and set it to 0 your done.. Quote Link to comment Share on other sites More sharing options...
e.mounir Posted September 1, 2008 Share Posted September 1, 2008 Tray used Express >>layout>> ALIGNSPACE it will be good result Quote Link to comment Share on other sites More sharing options...
GE13579 Posted September 1, 2008 Share Posted September 1, 2008 The way I would rotate a viewport is MVSETUP- ALIGN- ROTATE VIEW, although it can be a bit tempremental at times. Quote Link to comment Share on other sites More sharing options...
