Hi all,
I got a new problem this morning that I have never seen before. In model space it is like it is frozen. it will not zoom in or out. says it is as far as possible both directions. Layout tabs work fine and so do my view ports? I did down load the second maintenance file yesterday. has any one dealt with this before. I have restarted, reloaded and audited the file.
Any help is appreciated.
Thanks
  • 1 month later...
Can you do a zoom all or extents? In model space what are your drawing limits set to?
draw a line that is several thousand feet long, then zoom extents. The other thing you might try is to regenerate your drawing. that should fix it.
