Image Traceing
Vidiot
I do drawings for Audio/Video system design. Typically when I'm doing rack elevations I will either get .dwg's from the manufacturer and WBLOCK the parts needed or just make rectangles of the apropriate size with the gear name in it. For times when I cannot get the CAD files is there a way to import an image file and draw over it? Is there a way to auto generate this? I only ask cause I've opened files and they dont seem to be like they have been draw by hand.
Sorry if this is a noob Q.
I assume that is the same as Insert,Raster Image Reference. I just used this insert the image. Cool. Now I can trace it. Is there a better way?
I dont think there is an easier way of copying an image but you might want to search the forums and see what you come up with
