Where has my 3D Move Gizmo gone?
Bobzy20
Hi guys I wonder if you can help me with this small issue I’m having.
I’m currently running through this 3D Mesh Tutorial on YouTube:
http://www.youtube.com/watch?v=tI5EyFw4agM
Whenever I select the Mesh object I’m drawing my Gizmo doesn’t appear.
DEFAULTGIZMO is set to value 0
GTAUTO is set to value 1
Any help would be great.
Thanks
Bobzy20
Hi,
Change your visual style to 3d wireframe
Home tab/View panel/select 3d wireframe
see the differente between 2D and 3D wireframe
In 2D no gizmo see image below
bye
Pascal
Thanks very much for that guys that worked well.
I also noticed under the Render tab in the tutorial he has a panel called ‘Edge Effects’ but I don’t seem to have that, how can I add that panel in?
Thanks
Bobzy20
