Well some I got the question that there could be renumbering the parts...
Okey renumbering drawing names are easy but the blocks are the real problem.
I have 3 views front view side view and top view.
They have numbers and should change...
Now my idea was:
Change filename to new number, goes mostly automatic.
And then: Rename *-TV* to dwgname-TV
This all works fine when you use the rename menu, but the wild tags don't work in the command window. So simple -rename "b" "*-TV*" "dwgname-tv" doesn't work.
Job offers are welcome too... :P
You could step through your block definitions and use vl-string-subst on any block name that matches your criteria. You could use wcmatch or vl-string-search to weed out the blocks that match.
