MantaBase Posted September 1, 2008 Share Posted September 1, 2008 If this is better in the beginners area, my apologies. Begin: Typically, when I open a new drawing, I make a new layout (Arch E size). That layout typically has a viewport in it that I can resize. I paste in my dynamic title block. Answer some questions. Resize the viewport to fit the title block. Etc... Now, I have a drawing that I have been working on for sometime. I need to make an Arch D layout. For some reason, whenever I create a new layout, the viewport is on the layout and I can not modify (resize it). Nor can I paste in my block. Ideas? I checked a new file just to be sure, and it works like I expected (I can resize the view port and past in a block on the paper layout. I'm stumped. What am I missing? (FYI - my background is GIS, so if I used any wrong terms, please forgive). Manta Quote Link to comment Share on other sites More sharing options...
MantaBase Posted September 1, 2008 Author Share Posted September 1, 2008 If this is better in the beginners area, my apologies. Begin: Typically, when I open a new drawing, I make a new layout (Arch E size). That layout typically has a viewport in it that I can resize. I paste in my dynamic title block. Answer some questions. Resize the viewport to fit the title block. Etc... Now, I have a drawing that I have been working on for sometime. I need to make an Arch D layout. For some reason, whenever I create a new layout, the viewport is on the layout and I can not modify (resize it). Nor can I paste in my block. Ideas? I checked a new file just to be sure, and it works like I expected (I can resize the view port and past in a block on the paper layout. I'm stumped. What am I missing? (FYI - my background is GIS, so if I used any wrong terms, please forgive). Manta Dear Manta, You might try making sure that the layer you have active when you create a new layout is actually on. lol - That did the trick. Manta Quote Link to comment Share on other sites More sharing options...
Strix Posted September 1, 2008 Share Posted September 1, 2008 glad that's all cleared up I was going to ask if your viewport was locked :wink: Quote Link to comment Share on other sites More sharing options...
