This is a pretty big ask, but i was wondering if anyone knew of a lisp program (or how to write one) that would generate a list of layers in a drawing by using selected block names.
i.e. I select 2 blocks (called Block1 & Block2) and press a button & then 2 layers will be created with this name?.. If they could be moved onto the layer as well that would be useful.
& my second (& probably even bigger) ask is would it be possible to create something that will put a number next to each line on a certain layer with its dimension in metres?...
i.e. if i have a 3m x 3m square drawn on "Layer1", i then press a button & it will put the number "3" on the outside of each line on the sqaure.
Both big asks but any help (or nudge in the right direction) would be greatly appreciated.
Hi
This Lisp will take the name of the selected Block and create a Layer holding the Block's Name
Block Layer would be Current , Continuous and Red Color .
(defun c:blk (/ Ent BlkEnt blkNme )
 (setq Ent (car(entsel "\n Select a Block: "))
BlkEnt (entget Ent)
BlkNme (cdr (assoc 2 BlkEnt))
   (vl-cmdf "_.-layer" "_m" BlkNme "ltype" "continuous" "" "color" "red" "" "")
 (setvar "clayer" BlkNme)
Regards.
Tharwat
Great!.. thanks! Is there a way to make it so I can group select a few blocks?
This should be a lot faster:
(defun c:Blk2lay ( / ss )
 ;; © Lee Mac 2010
 (if (setq ss (ssget '((0 . "INSERT"))))
     (lambda ( i / e done )
       (while (setq e (ssname ss (setq i (1+ i))))
         (if (not (member (cdr (assoc 2 (entget e))) done))
             (entmake
               (list
                 (cons 0 "LAYER")
                 (cons 100 "AcDbSymbolTableRecord")
                 (cons 100 "AcDbLayerTableRecord")
                 (cons 70 0)
             (setq done (cons (cdr (assoc 2 (entget e))) done))
         (entupd
           (cdr
             (assoc -1
               (entmod
                 (subst
                   (cons 8 (cdr (assoc 2 (entget e))))
                   (assoc 8 (entget e))
                   (entget e)
     -1
That is awesome!... Works a treat!.. Thanks guys!
Hi
   BlkEnt (entget Ent)
Regards.
Tharwat
FYI, when you use the MAKE option with Layer, the created layer will be set as current. No need to worry with setting clayer variable.
The auto dimensioning of lines or plines is pretty easy just a case of making a list of the lines and getting their length and putting text at the mid point.
Hard part is getting text the correct side of the lines you may need a yes no for each.
Heres an old one but a good starting point gives you most of the answers to create your own.
;SETOUT3.LSP
; program to draw setout details as a co-ord list
; with co-ords to two points
; 29/7/01 by alan
(setvar "menuecho" 0)
(setvar "SNAPMODE" 0)
(COMMAND "STYLE" "MYDEFAULT" "ISO3098b" 0.0 1.0 0.0 "N" "N" "N")
(setq oldangbase (getvar "angbase"))
(setq oldangdir (getvar "angdir"))
(setq oldaunits (getvar "aunits"))
(setvar "angbase" 0.0)
(setvar "angdir" 0)
(setvar "aunits" 3)
(SETQ SETSC (GETREAL "\nWhat is overall scale 1 ?  "))
(SETQ TXTHT (* 1.75 setsc)) ;CHANGE TO ASK FOR FINAL PLOT SCALE
(while
(SETVAR "OSMODE" 1)
(setq pt1 (getpoint "\nPick 1st point, press <cr> to exit"))
(setq pt2 (getpoint "\nPick next point, press <cr> to exit"))
(SETQ DIST (DISTANCE PT1 PT2))
(SETQ DISTMID (/ DIST 2.0))
(SETQ ANG (ANGLE PT1 PT2))
(setq pt3 (polar pt1 ANG DISTMID))
(setq pt3 (polar pt3 (+ ang 1.5707) 1.5))
(SETQ BLOCKLEN (RTOS DIST 2 2))
(SETVAR "OSMODE" 0)
(command "text" "MC" pt3 txtht ANG BLOCKLEN)
(setq flip (getstring "\nFlip text 180 press f  "))
(if (or (= flip "f")(= flip "F"))
(command "rotate" "l" "" pt3 3.14159)
)                                                   ; end while
(setvar "angbase" oldangbase )
(setvar "angdir" oldangdir)
(setvar "aunits" oldaunits)
(setq pt1 nil
     pt2 nil
     pt3 nil
     pt4 nil
     pt5 nil
     pt6 nil
     stpt nil
     ans nil
Therse another post today also about text to lines.
Thanks for that Bigal... That should be enough for me to butcher :D
