roaddawgjim Posted July 27, 2010 Share Posted July 27, 2010 I'm new to autocad 2009 when in a drawing after I dimension something I cant get the text after the dimension such as r2.00 typ I can only get typ before the dimension please help Quote Link to comment Share on other sites More sharing options...
lpseifert Posted July 27, 2010 Share Posted July 27, 2010 Select the dimension In Properties > Text override, enter typ Quote Link to comment Share on other sites More sharing options...
HassanCAD® Posted July 27, 2010 Share Posted July 27, 2010 set the fits of your dim...related to your limits Quote Link to comment Share on other sites More sharing options...
f700es Posted July 27, 2010 Share Posted July 27, 2010 You can also type "ed" and then select your dim and edit it there and if you want the text under the dim use this.. (orig dim)\X_your text (_ = a space) Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 27, 2010 Share Posted July 27, 2010 set the fits of your dim...related to your limits HassanCAD: Your answer does not apply to this situation. Another option is to add the text \XTYP after the brackets . This will result in the letters TYP appearing below the dimension. It comes in handy when space is at a premium. Quote Link to comment Share on other sites More sharing options...
