RoguePiper Posted August 3, 2010 Share Posted August 3, 2010 I have a piping isometric that is not drawn to scale that needs to have the imperial dimensions added. The drawing is currently dimensioned in metric with all dimensions having a text override. I am looking for a way to take the text that is in the override and adding the imperial equivalent ie 300 changed to 300 [11.811]. Is this possible with a Lisp? Will the numbers in the text override be able to be converted? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 3, 2010 Share Posted August 3, 2010 hello , I also asked a question about Dimensions before, and unfortunetly one body has answerd my question except Mr Kerry Brown, and the following link belong to his great codes that also he supported me with. So check it out . http://www.theswamp.org/index.php?topic=10317.msg131450#msg131450 Regards, Tharwat Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 3, 2010 Share Posted August 3, 2010 Perhaps something like this? (defun c:ImpDim ( / ss ) ;; © Lee Mac 2010 (if (setq ss (ssget "_:L" '((0 . "DIMENSION")))) ( (lambda ( i / e s n ) (while (setq e (ssname ss (setq i (1+ i)))) (if (and (setq s (cdr (assoc 1 (entget e)))) (setq n (distof s))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat s " [" (rtos n 3) "]")) (assoc 1 (entget e)) (entget e) ) ) ) ) ) ) ) ) -1 ) ) (princ) ) It assumes that the original Dimension Override is purely a number however. Quote Link to comment Share on other sites More sharing options...
RoguePiper Posted August 3, 2010 Author Share Posted August 3, 2010 Thanks for info. I will look into both. Lee Mac, I will give yours a try, the original are all numbers. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 3, 2010 Share Posted August 3, 2010 Thanks for info. I will look into both. Lee Mac, I will give yours a try, the original are all numbers. Have you tried it mr Rogue? For me, it is not working although the racism is very clear in that reply !!!!! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 3, 2010 Share Posted August 3, 2010 Have you tried it mr Rogue? For me, it is not working although the racism is very clear in this reply !!!!! WTH? Racism? Did I miss something? Grow up Tharwat. Quote Link to comment Share on other sites More sharing options...
RoguePiper Posted August 3, 2010 Author Share Posted August 3, 2010 Racism? hmmmmm , a little difficult to be racist when I have no idea what race you or anyone else is. Lee Mac posted a specific script, your post was a link to a very informative post that seems more like a tutorial. I have not had a a chance to try it. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 3, 2010 Share Posted August 3, 2010 WTH? Racism? Did I miss something? Grow up Tharwat. can you see the difference between this thread and the following link thread ? http://www.cadtutor.net/forum/showthread.php?50963-Update-the-contents-of-a-Dimension-Style And there are lots of things to get..... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 3, 2010 Share Posted August 3, 2010 can you see the difference between this thread and the following link thread ?http://www.cadtutor.net/forum/showthread.php?50963-Update-the-contents-of-a-Dimension-Style And there are lots of things to get..... That is not racism, and it clearly reflects how immature you are to suggest such an absurd claim. Do you really expect me to answer every thread on this forum, and hold it against me if I don't? In any case, some of us aren't too tolerant of the code plagiarism you have demonstrated in the past. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 3, 2010 Share Posted August 3, 2010 That is not racism, and it clearly reflects how immature you are to suggest such an absurd claim. Since that you consider your self a mature, your answer should be more polite. Do you really expect me to answer every thread on this forum, and hold it against me if I don't? I do not expect any thing from you since is that is one of your answers. In any case, some of us aren't too tolerant of the code plagiarism you have demonstrated in the past. And I am not waiting for your tolerance at all, beside that, I am very proud of what I am doing and saying and so on...... And if you consider your self is the father of all , its up to you. And of course me is excluded. your replies claim what you think of ...... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 3, 2010 Share Posted August 3, 2010 Since that you consider your self a mature, your answer should be more polite. I did not consider my response in any way rude - I stated my opinion of your previous response in a clear and concise manner. I do not expect any thing from you since is that is one of your answers. Your previous response suggested that I displayed 'racism' (I think you need to look that word up) towards you since I did not reply to your thread. And I am not waiting for your tolerance at all, beside that, I am very proud of what I am doing and saying and so on...... If that is your view, then we quite clearly disagree on what we consider to be good coding etiquette. But I would prefer if you didn't throw a tantrum should I decide not to answer your future threads. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 3, 2010 Share Posted August 3, 2010 Your previous response suggested that I displayed 'racism' (I think you need to look that word up) towards you since I did not reply to your thread. I have told you before that I do not care if you reply or not. Because you do not give something to be learned by any, you only show your muscles infront of people. And that's not what I am looking for .... I decide not to answer your future threads. Please not do reply to my threads at all, since that you will show your prouds againt others, which is completely I hate this kind of habit. When you become more modest, you would be welcomed in that time only. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 3, 2010 Share Posted August 3, 2010 I have told you before that I do not care if you reply or not. Then why shout 'racism' ? Because you do not give something to be learned by any, you only show your muscles infrontof people When you become more modest, you would be welcomed in that time only. Oh right, I forgot I am only allowed to post code that Tharwat is able to understand. Complexity of code is a matter of opinion: I cannot see how you can reprimand my lack of modesty for posting code just because you feel it is too complex. Quote Link to comment Share on other sites More sharing options...
Lt Dan's legs Posted August 3, 2010 Share Posted August 3, 2010 to tharwat313, I'm not trying to be mean or a d*ck but I've come here to learn, not to argue www.cadtutor.net homepage "CADTutor delivers the best free tutorials and articles for AutoCAD, 3ds Max and associated applications along with a friendly AutoCAD forum and an AutoCAD FAQ. If you need to learn AutoCAD, you're in the right place." The way I see it, if you cannot post without getting into an arguement or offend others than maybe this site isn't for you. If you dissagree, just ignore this post. I like to keep stress out of my life as much as possible and you'll be much happier if you do the same. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 3, 2010 Share Posted August 3, 2010 Then why shout 'racism' ? Because it is the truth. As I told you a long time a go that you do not give a complete help unless someone initiate, And in that time muscles would be shown clearly. Oh right, I forgot I am only allowed to post code that Tharwat is able to understand. Complexity of code is a matter of opinion: I cannot see how you can reprimand my lack of modesty for posting code just because you feel it is too complex. You still can not get my point well , And that's for sure due to your up rised nose against others. or a toss. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 3, 2010 Share Posted August 3, 2010 to tharwat313' date='[/b'] I'm not trying to be mean or a d*ck but I've come here to learn, not to argue www.cadtutor.net homepage "CADTutor delivers the best free tutorials and articles for AutoCAD, 3ds Max and associated applications along with a friendly AutoCAD forum and an AutoCAD FAQ. If you need to learn AutoCAD, you're in the right place." The way I see it, if you cannot post without getting into an arguement or offend others than maybe this site isn't for you. If you dissagree, just ignore this post. I like to keep stress out of my life as much as possible and you'll be much happier if you do the same. You must be reading what I have inside. So your advise must be given to someone else. I thank you for your kind reply. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 3, 2010 Share Posted August 3, 2010 Because it is the truth. As I told you a long time a go that you do not give a complete help unless someone initiate, And in that time muscles would be shown clearly. I answer the threads that I want to answer - I don't know what you are talking about. 'Muscles'? I'm not going to post 'simple' code just so that Tharwat can understand it, believe it or not, there are those who benefit from more challenging code. You still can not get my point well , And that's for sure due to your up rised nose against others. or a toss. Again, I don't know how you draw these conclusions but it is obvious that you are only here to cause trouble. If you don't like the complexity of my code I suggest you ignore it. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 3, 2010 Share Posted August 3, 2010 (edited) to tharwat313' date='[/b'] The way I see it, if you cannot post without getting into an arguement or offend others than maybe this site isn't for you. I think this is getting out of hand... Really- the combative nature and the allegations of racism. I would suggest that everybody ignore his threads/posts and maybe he'll go away. Edited August 4, 2010 by lpseifert Quote Link to comment Share on other sites More sharing options...
RoguePiper Posted August 3, 2010 Author Share Posted August 3, 2010 Lee Mac, that is very close to what I was looking for. Thanks you very much. Lets see if we can get this back on track. I just need to tweak it a little bit to make it perfect. Right now it is taking the text as inches and just converting to feet inches, my dimensions are all in mm and need to be converted to decimal inches, to 3 decimal places. And I need to have the imperial dimension appear below the dimension line, so I just need to add a \X into the text string, but not quite sure where that would go. Quote Link to comment Share on other sites More sharing options...
RoguePiper Posted August 4, 2010 Author Share Posted August 4, 2010 I changed the code to convert the dimension into inches now. I changed to this (setq n (/ (distof s) 25.4))) When I try and get the text to display below the dimension line by adding the \X to the string, it drops the \ and only adds the X. Any suggestions? Full modified code (defun c:ImpDim ( / ss ) ;; © Lee Mac 2010 (if (setq ss (ssget "_:L" '((0 . "DIMENSION")))) ( (lambda ( i / e s n ) (while (setq e (ssname ss (setq i (1+ i)))) (if (and (setq s (cdr (assoc 1 (entget e)))) (setq n (/ (distof s) 25.4))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat s " [" (rtos n 2 3) "]")) (assoc 1 (entget e)) (entget e) ) ) ) ) ) ) ) ) -1 ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
