Bailey Posted August 5, 2010 Posted August 5, 2010 Hi there I've just started playing with Autocad MEP 2010 and i seen to have got stuck on a few things and i was hopeing you guys could help. First i'm creating a 2 level building, the first level is at 0 elevation and the second level is at 3000mm elevation. now when i draw a wall on the second elevation i cant see it in pland view?? do i need to cahnge the view point some how? Second, how do you conect the to levels as thay dont seam to be conected? thanks for the help in advance cheers Paul Quote
tzframpton Posted August 5, 2010 Posted August 5, 2010 You should look into using the Project Navigator. There's extensive material in the Help file about this feature. It will allow you to create Levels, along with Constructs and other handy tools. It's got quite a learning curve but worth it in the end. Hope this helps. Quote
