AGordon89 Posted August 19, 2010 Share Posted August 19, 2010 Hello there I am in need of help and some what of a beginner. I have drawn a large building model and exported a dxf. The dxf is a autocad_3dpolyline. I need this to be a solid object(s), I can use software AutoCAD 2009, 3ds max 2009 and FME. If there is anybody that could help, i would be very greatful. If there is any more infomation you need to know just let me know. Thanks in advance Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 19, 2010 Share Posted August 19, 2010 In AutoCAD 2009 you can use the Extrude or Press/Pull commands to create solids and surfaces. Quote Link to comment Share on other sites More sharing options...
AGordon89 Posted August 19, 2010 Author Share Posted August 19, 2010 But i have about 500 buildings of the centre of Leicester city centre. All the geometry is there, individual building heights and each building has a unique Z value as the buildings have been modeled of a Digital Terrain. I just need to convert these wire frame polylines into something solid. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 19, 2010 Share Posted August 19, 2010 Ahhh...an important piece of information is revealed. So when you opened the DXF file all the Z values were lost? Quote Link to comment Share on other sites More sharing options...
AGordon89 Posted August 19, 2010 Author Share Posted August 19, 2010 No, all the geometry and values are there and ok. It just the make-up of the building needs to be solid, but it isn't. Just 3dpolylines Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 19, 2010 Share Posted August 19, 2010 Sounds almost like someone built the buildings as wireframes using 3Dpolylines. Quote Link to comment Share on other sites More sharing options...
AGordon89 Posted August 19, 2010 Author Share Posted August 19, 2010 Anyway to make them solids in AutoCAD2009?? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 19, 2010 Share Posted August 19, 2010 Anyway to make them solids in AutoCAD2009?? Yes, lots of work or request solid model from owner of intelllectual property - perhaps there is a reason it was released as wireframe? I have drawn a large building model .... Now wait, if you drew the model why did you do as wireframe rather than as solid. Something doesn't add up here? Quote Link to comment Share on other sites More sharing options...
AGordon89 Posted August 19, 2010 Author Share Posted August 19, 2010 Yes, lots of work or request solid model from owner of intelllectual property - perhaps there is a reason it was released as wireframe? Now wait, if you drew the model why did you do as wireframe rather than as solid. Something doesn't add up here? The software i had to draw 5 square kilometes of a city centre is about 9 years old(I know how rubbish that is). There is no option to draw as a solid or wireframe. There is no preference for this. I am looking for other software in which i can use stereo pairs of photography & LiDAR data to build large scale data sets. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 19, 2010 Share Posted August 19, 2010 AGordon89, you really need to supply all pertinent information when asking for help. I was trying to help him with this on another forum and he said he used a program called Socet Set to create the building. I told him he needed to start over and create the buildings from scratch using Autocad's 3D modeling tools. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 19, 2010 Share Posted August 19, 2010 Assuming you have a decent dwx wireframe to work from you could create the solids rather quickly (a lot quicker than starting from scratch), but of course you would have to have a strong understanding of AutoCAD. Sounds like this might be a good project for gaining that experience. If you were looking for the Easy Button, there isn't one. Quote Link to comment Share on other sites More sharing options...
