NoneShallSleep Posted August 25, 2010 Share Posted August 25, 2010 I looked around, and couldn't find anything that answered this question specifically. So here goes: I've got hidden viewports to show my 3D objects in. These objects require label text that I've created in paperspace to align with them. Is there any way to get the text to plot as solid instead of outlined from these viewports set to hidden? Thank you in advance! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 26, 2010 Share Posted August 26, 2010 The Shademode setting of your viewport should not affect your paper space text. At least it doesn't in 2010. Not sure about 2006 though? What font are you using? Quote Link to comment Share on other sites More sharing options...
NoneShallSleep Posted August 26, 2010 Author Share Posted August 26, 2010 I'm on 2006 ... If I set the viewport to wireframe the text will print solid, but then that also renders the 3D objects in wireframe. Quote Link to comment Share on other sites More sharing options...
