engwizard Posted August 27, 2010 Posted August 27, 2010 please can any one help me in trimming the attached drawing valve.dwg Quote
ReMark Posted August 27, 2010 Posted August 27, 2010 I assume you what to get rid of any protrusions on the outside of the valve, right? Quote
ReMark Posted August 27, 2010 Posted August 27, 2010 exactly that what i want I thought so. I see everything has been unioned together already. I stand corrected. That is not the case with the objects inside the valve body. Quote
engwizard Posted August 27, 2010 Author Posted August 27, 2010 i didn't find any solution for this problem Quote
ReMark Posted August 27, 2010 Posted August 27, 2010 Make a copy of your geometry to one side. Subtract the main valve body from the four(?) knife gates(?) inside. Use the Separate command to create individual pieces. Erase what you don't need. Substitute what's left for the same parts in the original. Do not union these together unless you absolutely have to. Quote
ReMark Posted August 27, 2010 Posted August 27, 2010 Yep...it can be done. Like I said, use the Subtract command and the Separate command. There is no 3DTrim command although there is a Slice command but I'm not sure how much easier it would be to use in this situation. Quote
JD Mather Posted August 27, 2010 Posted August 27, 2010 Revolve arc as surface body. Slice with surface option. Quote
ReMark Posted August 27, 2010 Posted August 27, 2010 Revolve arc as surface body.Slice with surface option. I knew if anyone could do it quicker and easier it would be JDM! Quote
engwizard Posted August 27, 2010 Author Posted August 27, 2010 thank you every body your suggestions was great Quote
