jbird68 Posted August 27, 2010 Posted August 27, 2010 Is there a quick and easy way to build a chart, like a BOM, on a drawing? Sort of like excel where you can pick number of rows, text height, etc. Quote
BlackBox Posted August 27, 2010 Posted August 27, 2010 I don't have mechanical, so I'm not sure if this command is available to you or not... Have you tried the ._table command? Quote
tzframpton Posted August 27, 2010 Posted August 27, 2010 RenderMan is correct. A Table is what you're after. Works and operates like Excel does. Quote
BlackBox Posted August 27, 2010 Posted August 27, 2010 RenderMan is correct. A Table is what you're after. Works and operates like Excel does. Thanks for the confirmation, StykFacE! Quote
ReMark Posted August 27, 2010 Posted August 27, 2010 Looks like the OP may be out of luck re: Table. His version is 2004. I don't think tables were introduced until 2007. He may have to go the old excel spreadsheet route inserted as an OLE object. Quote
tzframpton Posted August 28, 2010 Posted August 28, 2010 Good eye, Mark. The benefit of subscription.... always get the latest options. Quote
