Burner Posted August 30, 2010 Posted August 30, 2010 How do I get certain dimensions and multi-leaders to show up in different viewports with the same scale? I have two viewports, iso and plan. I want to show only dimensions in the plan viewport while only multi-leaders in the iso viewport. Thanks Quote
rkent Posted August 30, 2010 Posted August 30, 2010 Use multiple layers for your dims and mleaders, freeze/thaw per viewport to show what you want. One way is to work through the viewport and use the layfrz command, select an object on a layer you don't want to show. Quote
edwinprakoso Posted September 1, 2010 Posted September 1, 2010 Another option is: You can place the dimensions on layout. Quote
