jimpcfd Posted September 2, 2010 Posted September 2, 2010 Hi Overkill does not work after running a lisp routines!!! i'm sure it's the lisp files that are causing the problem. attached are the file.p$rules calculates lengths of layers (rules) p$list has the layer names and colours thanks jimpcfd P$RULES.LSP P$LLIST.LSP Quote
JohnM Posted September 2, 2010 Posted September 2, 2010 Localize your variables and that might solve your issues Quote
jimpcfd Posted September 3, 2010 Author Posted September 3, 2010 Hi Johnm i'm just a beginner with lisp stuff although have been using autocad for 24 years, so how do i localize the variables in these files ? thanks jimpcfd Quote
JohnM Posted September 3, 2010 Posted September 3, 2010 Localizing variables are a must if you want your routine to not interfere with other routines. A lisp is laid out with a open parentheses then the Defun then its calling name then a open parentheses and an closed parentheses then what ever code you write, then a closing parentheses (defun c:test ( / ) code here );_end of defun It’s in the parentheses after the calling name where you localize the variables. The contents of the parentheses are broken down into 2 sections divided by a forward slash example: (aug1 aug1……/ local variables) If you are passing info to a defun the info is passed to the variables to the left of the forward slash these are called arguments. You can have as many arguments and needed then to the right of the forward slash you list your local variable. Local variable ar the one you create in the body of the code. (defun c:test ( / a b c );_localized variables (setq a 1) (setq b 2) (setq c (+ a b )) );_end of defun Localizing variable will make them all nill when the routine ends otherwise they will still be active and hold their values assigned to then in the code Passing arguments: (defun test (aug1 aug2 / a b c );_localized variables and arguments (setq a aug1) (setq b aug2) (setq c (+ a b )) );_end of defun In the example above the defun needs 2 arguments passed to it or it will error out and also the calling name has the c: removed. Theses type of routines are called sub-routines To properly call this routine you must know what type of arguments to pass to it In this case it needs 2 integers. Here is how you would call this routine (setq ret (test 5 10) ) This calls the test sub-routine and passes the integers 5 & 10 to it that are now assigned to aug1 and aug2. The routine processes the info then returns an answer The answer is 15 and is returned to the variable ret in the call (setq ret (test 5 10) ) These are basic example and could get much more complicated but this should give you a good place to start Quote
Lee Mac Posted September 3, 2010 Posted September 3, 2010 John, You could format your code in code tags, read this: http://www.cadtutor.net/forum/showthread.php?9184-Code-posting-guidelines Quote
JohnM Posted September 3, 2010 Posted September 3, 2010 Lee, I normally code tag my posted codes but in this situation they where just small examples not meant to be copied or used Quote
Lee Mac Posted September 3, 2010 Posted September 3, 2010 Lee,I normally code tag my posted codes but in this situation they where just small examples not meant to be copied or used No worries, I just thought it might look clearer and wondered whether you knew how Quote
jimpcfd Posted September 6, 2010 Author Posted September 6, 2010 Hi Johnm i understand what you are saying, does that also apply to none defun c:test ( / ) ie defun test() ? Quote
JohnM Posted September 6, 2010 Posted September 6, 2010 Yes. If you read my post you will see the example defun test The c: in the calling name means it is a command line call Look in the developers help file in AutoCAD and look up defun for a definition Quote
