Hi
Here is my problem.
When I open up AuyoCad 2000, it goes to a new drawing.
It use to open a small window o let me pick either standers or metric dimensions.
How can I git it back to where it will?
Thank you for your time.
Sam Gurrera
IF you mean type it in the command space, it didn't work.
I hate to reload AutoCads back in, because it might change all my setting,
I an going to try to start my computer at an earlyer date and see if that works.
TODAY was not introduced until 2004. Try the system variable STARTUPTODAY, although I don't think this was around until 2000i..
Poke around in the Options dialog if STARTUPTODAY is invalid. I don't have access to 2000 any more...
Reloading AutoCAD probably won't help, but even if you did, you won't lose any settings unless you specifically remove user created files/registry settings.
A reinstall simply replaces program files with the original.
The (restore my computer to an earlier time) worled.
Thanks Sam Gurrera
