Heyner Posted September 11, 2010 Share Posted September 11, 2010 Hello everyone: I'm updating some old code of mine and I want to get ride of using the shell command, you know why. I need to create a folder, this is what's written now to create the folder num_br: (setq commd (strcat "md " " Quote Link to comment Share on other sites More sharing options...
Heyner Posted September 11, 2010 Author Share Posted September 11, 2010 (setq commd (strcat "md " " Quote Link to comment Share on other sites More sharing options...
Heyner Posted September 11, 2010 Author Share Posted September 11, 2010 Sorry I tried to post the code twice and failed, you can see i'm obviously newbie. The idea is to use a vl command to create a folder. Which's that command? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted September 11, 2010 Share Posted September 11, 2010 from Developer Help > AutoLISP Reference vl-mkdir Creates a directory (vl-mkdir directoryname) Arguments directoryname The name of the directory you want to create. Return Values T if successful, nil if the directory exists or if unsuccessful. Examples Create a directory named mydirectory: _$ (vl-mkdir "c:\\mydirectory”) T Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 11, 2010 Share Posted September 11, 2010 vl-mkdir can make a single folder, so this is what I use to create a directory structure: [i][color=#990099];;-------------------=={ Make Directory }==-------------------;;[/color][/i] [i][color=#990099];; ;;[/color][/i] [i][color=#990099];; Creates a directory structure ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [i][color=#990099];; Author: Lee McDonnell, 2010 ;;[/color][/i] [i][color=#990099];; ;;[/color][/i] [i][color=#990099];; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;;[/color][/i] [i][color=#990099];; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [i][color=#990099];; Arguments: ;;[/color][/i] [i][color=#990099];; dir - the directory to create ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [i][color=#990099];; Returns: T if directory creation is successful, else nil ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] [color=black]LM:MakeDirectory[/color] [b][color=RED]([/color][/b] dir [b][color=BLUE]/[/color][/b] MakeDirectory folders [b][color=RED])[/color][/b] [i][color=#990099];; © Lee Mac 2010[/color][/i] [i][color=#990099];; (LM:MakeDirectory "C:\\Folder\\Subfolder")[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] MakeDirectory [b][color=RED]([/color][/b] root folders [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] folders [b][color=RED]([/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b] dir [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-mkdir[/color][/b] dir[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]MakeDirectory dir [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] folders[b][color=RED]))[/color][/b] [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] root [b][color=#a52a2a]"\\"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] folders[b][color=RED]))[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] folders [b][color=RED]([/color][/b][color=black]LM:str->lst[/color] [b][color=RED]([/color][/b][b][color=BLUE]vl-string-translate[/color][/b] [b][color=#a52a2a]"/"[/color][/b] [b][color=#a52a2a]"\\"[/color][/b] dir[b][color=RED])[/color][/b] [b][color=#a52a2a]"\\"[/color][/b][b][color=RED]))[/color][/b] [b][color=RED]([/color][/b]MakeDirectory [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] folders[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] folders[b][color=RED]))[/color][/b] [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-file-directory-p[/color][/b] dir[b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [i][color=#990099];;-------------------=={ String -> List }==-------------------;;[/color][/i] [i][color=#990099];; ;;[/color][/i] [i][color=#990099];; Separates a string into a list of strings using a ;;[/color][/i] [i][color=#990099];; specified delimiter string ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [i][color=#990099];; Author: Lee McDonnell, 2010 ;;[/color][/i] [i][color=#990099];; ;;[/color][/i] [i][color=#990099];; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;;[/color][/i] [i][color=#990099];; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [i][color=#990099];; Arguments: ;;[/color][/i] [i][color=#990099];; str - string to process ;;[/color][/i] [i][color=#990099];; del - delimiter by which to separate the string ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [i][color=#990099];; Returns: A list of strings ;;[/color][/i] [i][color=#990099];;------------------------------------------------------------;;[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] [color=black]LM:str->lst[/color] [b][color=RED]([/color][/b] str del [b][color=BLUE]/[/color][/b] pos [b][color=RED])[/color][/b] [i][color=#990099];; © Lee Mac 2010[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pos [b][color=RED]([/color][/b][b][color=BLUE]vl-string-search[/color][/b] del str[b][color=RED]))[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]substr[/color][/b] str [b][color=#009900]1[/color][/b] pos[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][color=black]LM:str->lst[/color] [b][color=RED]([/color][/b][b][color=BLUE]substr[/color][/b] str [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] pos [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strlen[/color][/b] del[b][color=RED])))[/color][/b] del[b][color=RED]))[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] str[b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] Quote Link to comment Share on other sites More sharing options...
Heyner Posted September 12, 2010 Author Share Posted September 12, 2010 Thank you very much, it is working perfectly as I wanted. Quote Link to comment Share on other sites More sharing options...
