xTNickx Posted September 27, 2010 Share Posted September 27, 2010 Hello! I use Autocad Land Desktop 2007 and I would like to start coding for it in ObjectARX. However, I don't seem to find 2007 version... As a side question, what VS should be used for this? I already tried to create a simple arx with VS 2008 and ObjectARX 2006, but autocad complains that: X.arx is incompatible with this version of AutoCAD where X is the name of my dll/arx. Thank you! Nick Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 27, 2010 Share Posted September 27, 2010 Here is a link to register for a license and download the current ObjectARX SDK's. You may have to Google AutoCAD 2007 ObjectARX SDK to find a suitable alternative download location for older SDK's. As I understand it, the current VS (Express/Full) should be sufficient, provided the appropriate SDK. Hope this helps! Quote Link to comment Share on other sites More sharing options...
xTNickx Posted September 28, 2010 Author Share Posted September 28, 2010 Thank you for your reply! I have found ObjectARX 2007 at http://download.autodesk.com/esd/objectarx/2007/Arx_All.exe I'll give it a try... Nick Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 28, 2010 Share Posted September 28, 2010 Thanks for posting the link, mate. :wink: Quote Link to comment Share on other sites More sharing options...
xTNickx Posted September 28, 2010 Author Share Posted September 28, 2010 Hello! As a note for lost seeker that arrives at this post, I have tried OARX 2007 with VS Express 2008. Everything builds just fine, but Autocad complains: Unable to load X.arx file. So VS 2005 Express is required, maybe.. - followed the advices here for wizard (but didn't have time to check how it works) - and then I have opened the help; put the hello world example into my new project (console, then some tweaks in project properties) and compiled - VC throws LINK : fatal error LNK1104: cannot open file 'mfc80u.lib' (!) - Express => no mfc - provided some mfc folder and the dll/arx was build successfully (probably should provide mfc from VS 2005, but I have no such thing) And I have a running app now telling Hello world to the people Best regards, Nick Quote Link to comment Share on other sites More sharing options...
