Hello everyone,
I have a situation maybe you can help me with. I made a dynamic block for a Door. By default the door is closed so no arch is shown. However I would like to rotate the door to open at various degrees. So when I open the door I need to display an arch for the swing. I would like this arch to stretch itself along it's arch at various angles.
I tried a few things but i can't get the arc's geometry to stay put. Any thoughts?
Have you thought of using Visibility States for the various angles the door is open?
Edited by lpseifert
I'd rather not have a bunch of visibility states. but if that's the only solution then I will.
